09.11.2012, 13:36 MEZ
it depends on how many physics, if you are simulating the EM field, you could use the Definitions - gaussian function to modulate the spatial intensity distribution in X-Y (assuming you are propagating along Z) but then to get it to "focus down, you would need to add a phase term (as function of X-Y) to map the curvature at the entrence of your "inlet" boundary. By the way the simplest is probably to add a cylindrical coordinate along your beam axis and express everything in this coordinate frame, this reduces one dimension for the functions to define
09.11.2012, 15:28 MEZ
Thanks for advice.
I will try on that way.
Cheers
[QUOTE]
[/QUOTE]
Thanks for advice.
Cheers
