10.11.2012, 10:16 MEZ
COMSOL uses the "phasor approach so by using complex values for the amplitudes you can includ phase info to your frequency domain (harmonic) solver sweep analysis, check the doc, and I belive I have seen a model library of a 3 phse example, or was it on the model gallerie ?
It has alread ybeen discussed a few years ago, here on the Forum, the method is still the same ;)
10.11.2012, 12:51 MEZ
thanks a lot for your answer ivar
may i ask from you to put the link you mentioned? i couldnt find it.
10.11.2012, 13:11 MEZ
try a search on the Forum with PHASOR, and do the same on the help of COMSOL, and/or the PDF doc of the general user manual and the ACDC one
10.11.2012, 17:50 MEZ
thanks for your quick answer.
I found this link and it appears it would be useful but I use COMSOL 4.1 and this model has been written by a higher version so I cant load it. is it possible to open that? what should I do?
thanks in advanced
thanks in advanced
11.11.2012, 15:09 MEZ
link: http://www.comsol.com/community/forums/general/download/file/9293/Stator_3phase.mph
