Constant-current constant-voltage charging in lithium-ion model
I am trying to implement a constant-current constant-voltage charging strategy using the COMSOL standard lithium-ion battery model that comes with the chemical engineering module.
The idea is to apply a constant current to the cell until the voltage reaches some limit; after that point, apply constant voltage to the cell until cell current drops below some value. For the first segment of time, current is constrained and voltage is unconstrained. For the second segment of time, terminal voltage is constrained and current is unconstrained.
Does anyone know how to switch this boundary condition -- mid simulation -- to perform this operation?
Thanks.
2 Replies Last Post 23.02.2012, 21:03 MEZ
Posted: 2 decades ago 27.02.2010, 05:18 MEZ
this model maybe help you, if you have a valid license, you can get the pdf document how to use the model step by step.
www.comsol.com/showroom/gallery/686/
this model maybe help you, if you have a valid license, you can get the pdf document how to use the model step by step. http://www.comsol.com/showroom/gallery/686/
Posted: 1 decade ago 23.02.2012, 21:03 MEZ
Hello Gregory,
did you manage to find a solution for your problem. if yes, I would really appreciate if you could share it.
Thanks.
Hello Gregory, did you manage to find a solution for your problem. if yes, I would really appreciate if you could share it. Thanks.
