Henrik Sönnerlind
COMSOL Employee
2 years ago
16.10.2023, 09:43 MESZ
The User defined option in the Creep node allows only isotropic creep. You do however have a possibility to define a general anisotropic creep law by adding an Inelastic Strain Rate node.
If you are working in 3D, select a cylindrical coordinate system. Use the same coordinate system in the parent Linear Elastic Material node, so that you have access to the corresponding stress components.
If you are working in a 2D axisymmetric geometry, the cylindrical system is part of the formulation.
Henrik Sönnerlind
COMSOL
The *User defined* option in the *Creep* node allows only isotropic creep. You do however have a possibility to define a general anisotropic creep law by adding an *Inelastic Strain Rate* node.
If you are working in 3D, select a cylindrical coordinate system. Use the same coordinate system in the parent *Linear Elastic Material* node, so that you have access to the corresponding stress components.
2 years ago
17.10.2023, 14:22 MESZ
Thank you Henrik for your response. Your suggestion will help me a lot. However I am new to use inelastic strain rate node.
Can you please give me more explanations on how to use inelastic strain rate node to define this creep law.
Thank you very much for suggestions.
Henrik Sönnerlind
COMSOL Employee
2 years ago
18.10.2023, 08:24 MESZ
The entries are the components of the strain rate tensor. Essentially, you just have to select the format of the tensor (Diagonal or Symmetric) and then use the expressions from your first posting, but substituted with whatever the quantites would be called in your model. The stresses would be something like
sigma_t -> solid.s22
sigma_a -> solid.s33
Note that you need to provide the full tensor (even though you may decide to set some components to zero, assuming that there is no creep in that direction).
An important aspect is whether the physical creep process is volume preserving or not. If it is, the strain rate tensor must be designed to have that property. For example, the radial strain rate (not mentioned by you), cannot be chosen arbitrarily, since in this case it is required that trace(epsilon_dot) = 0.
Henrik Sönnerlind
COMSOL
2 years ago
20.10.2023, 06:56 MESZ
Thanks, Henric for your response.I will try it.
2 years ago
21.10.2023, 07:05 MESZ
Hi Henric,
First I described the creep rate equation in the variable subnode.
Then use it in the inelastic strain rate tensor, But I am facing many convergence errors.
Have a look on my model which I attached.
Thanks for your suggestions.
Hi Henric,
