Modeling a Phase Change Material Layer in a Heated Floor
Posted 01.11.2023, 08:18 GMT-4 0 Replies
I am seeking your expertise regarding a numerical model that I am currently developing in COMSOL Multiphysics. My objective is to model a phase change material layer integrated into a heated floor, and I would really appreciate any guidance on the physics to use as well as the associated equations.
Here is an overview of my project and the challenges I am encountering:
Geometry and Meshing:
I have already created the geometry of the multilayer heating element within COMSOL and generated a suitable mesh for the simulation.
Intended Physics:
I plan to include the following physics to model the heating phenomenon:
Heat transfer in the solid: To simulate the heat distribution throughout the floor layer.
Heat transfer in the fluid and laminar flow: My model involves fluid circulation within the heating layer when the phase change material transitions into the liquid phase.
Boundary and Initial Conditions:
I will define the appropriate boundaries and initial conditions for each physics module that I have selected.
Material Parameters:
I have defined the thermal and mechanical properties of the materials constituting the heating layer, such as thermal conductivity, thermal capacity, density, etc.
Questions:
- How can I define the solid/liquid fraction?
- How can I formulate the latent heat equation based on the fraction?
- Between these physics modules, namely, Heat transfer in the solid and Heat transfer in the fluid, where can I define the phase change material condition?
Thank you in advance for your time and support. I am looking forward to your valuable input on this matter.
Hello Afaf Charraou
