28.11.2012, 16:24 MEZ
You might give a better description of your model.
Your dipole - is it some kind of current source? And is there a corresponding sink, e.g. a ground BC at the outer boundary of the sphere? If not, there will be no current flow and therefore no magnetic field.
The mef interface seems the correct choice to me, assumed that I understood your model right.
29.11.2012, 13:46 MEZ
The dipole is an electric point dipole. But I don't see, why I would need a ground BC at the outer boundary.
Maybe you can explain that to me!
Normally, from the dipole results a potential and from the potential results an electric field. Then you can also compute the current density, depending on the different conductivities.
And if I have currents, there should be a magnetic field. If I treat my whole sphere as a space with epsilon0 and mu0, it should work.
But maybe with comsol it doesn't work that easy. As I said, I'm a beginner.
29.11.2012, 14:31 MEZ
Okay, I got something wrong. I thought you are talking about a point charge, not a point dipole. Do you try to simulate some kind of neural excitation in a skull?
So I guess there is maybe a problem with the way you modeled your dipole. If you are talking about a POINT dipole, how did you implement that. I mean the two poles should be separated or isolated in some kind of way.
You might model a small cylinder of isolating material, maybe 1 mm of diameter and 1 mm of length and assign the two circle areas two potentials, e. g. +1V and -1V...
Herzliche Grüße
Herzliche Grüße
29.11.2012, 15:01 MEZ
You're wrigth, I'm simulating neuronal excitation.
To implement the point dipole, I chose the one that's predefined, when you right-click magnetic and electric fields in your model and choose "points>electric point dipole". Then I defined the dipole moment, but then, as I said, didn't yield to any field.
I'll try out your suggestion, but maybe you've got an idea, why it doesn't work the way I did it first.
29.11.2012, 15:57 MEZ
I did not know about that dipole feature yet - but I tried it out right now. I got a reasonable solution in electrostatics but not in magnetic and electric fields, though I modeled exactly the same. Maybe this is some kind of bug - did you contact the COMSOL support with this topic?
