Heat continuity
Good afternoon!
I need an advice about how to use the heat continuity option please.
The task is to describe the following situation: in my model, there are some details that are physically not in touch. The reason is that the geometry is too complex and was imported from other software.
So, I need to take two close boundaries and describe them as there is a continuous medium there. I meen that the heat flux must be continuos there, such as no separated boundaries were there.
It seems to me that the option "Heat continuity" should be used here, but I couldn't do it in a correct way.
So I am asking for your kind help and advice please.
Makarenko Irina
2 Replies Last Post 05.12.2012, 14:18 MEZ
Posted: 1 decade ago 05.12.2012, 13:33 MEZ
To enforce the heat continuity constraint you should set up either an identity pair or a contact pair between the two surfaces. A contact pair works better in my experience if the surfaces are not perfectly aligned (with small gaps and/or overlaps).
Nagi Elabbasi
Veryst Engineering
To enforce the heat continuity constraint you should set up either an identity pair or a contact pair between the two surfaces. A contact pair works better in my experience if the surfaces are not perfectly aligned (with small gaps and/or overlaps). Nagi Elabbasi Veryst Engineering
Posted: 1 decade ago 05.12.2012, 14:18 MEZ
Thank you for the answer!
