Acculution ApS
Certified Consultant
2 years ago
11.02.2024, 05:59 GMT-5
Without seeing the model, it is difficult to say, as there could be some underlying issues. The short answer is to use Narrow Region as it is applicable in a more general sense, whereas for Bli you have an underlying assumption about the effects taking place on the surface (and there might also be some issues when curvature is present).
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
2 years ago
12.02.2024, 14:21 GMT-5
Updated:
2 years ago
Hi René,
Thank you for the reply, I always learn a lot from the discussions with you no matter whether here or on Linkedin.
Indeed, I noticed the results of narrow region acoustics fit better than BLI through the experiments but still underestimated the damping effect, so the SPL was boosted in the simulation while the experiment did not.
But I am also curious that in my opinion, I thought the boundary layer of this port is much thinner than the geometry, I thought the narrow region acoustics and the BLI should give similar results at least, but the results seemed to don't.
So I wonder is there any theoretical explanation for the discrepancies?
Thank you for the kind reply.
Hi René,
Acculution ApS
2 years ago
13.02.2024, 03:10 GMT-5
Updated:
2 years ago
13.02.2024, 05:32 GMT-5
Without seeing the file, it is difficult to say. What I would suggest is that you do a study independent of your loudspeaker case, and see when the Bli breaks down, and whether it under- or overestimates compared to narrow region. There is analytical expression to compare to also, if the geometry is simple. Also, the Bli calculates a tangential derivative, and there could something numerical issue depending on your mesh.
Acculution ApS
www.acculution.com
info@acculution.com
