Provide a solution to solve this error
Undefined variable. - Variable: comp1.spf.pA - Geometry: geom1 - Domains: 3-4 Failed to evaluate Jacobian of expression. - Expression: dvol_spatial(r(pi(2((WCH3t(comp1.plas.wCH3(-comp1.plas.rho)))+(comp1.plas.M_wCH3comp1.plas.R_wCH3))))) Failed to evaluate Jacobian of expression. - Expression: (2(-comp1.plas.rhocomp1.plas.wCH3WCH3ttest(WCH3)+comp1.plas.jr_wCH3test(WCH3r)+comp1.plas.jz_wCH3test(WCH3z)+comp1.plas.R_wCH3comp1.plas.M_wCH3test(WCH3))pir)(dvol_spatial)
1 Reply Last Post 30.03.2024, 19:52 MEZ
Robert Koslover Antennas, Waveguides, Electromagnetics
Posted: 3 years ago 30.03.2024, 19:52 MEZ
The full details and causes of an error condition can only occasionally be understood by inspection of Comsol software-generated error message(s) in isolation. I encourage you to post your .mph file to the forum, so that it can be reviewed by others here, and so that the issue(s) in your particular model will be easier to identify.
