All domains not applicable in Electrostriction multiphysics settings
Massimiliano Vallocchia
Hello everyone, I'm trying to simulate the effect of electric field on the mechanical properties of a capacitor. When I try to select domain for the Electrostriction multiphysics all domains are listed as not applicable. The geometry is formed as a union, COMSOL version 6.0, see attached file.
Tnx a lot in advance for any advice from a beginning but enthusiastic COMSOL user
3 Replies Last Post 23.05.2024, 06:40 GMT-4
Magnus Ringh COMSOL Employee
Posted: 2 years ago 22.05.2024, 08:30 GMT-4
Updated: 2 years ago 22.05.2024, 08:31 GMT-4
Hi Massimiliano,
The Electrostriction multiphyiscs node is not applicable because the Material type setting is set to Nonsolid in the Settings window for Charge Conservation in the Electrostatics interface. It should be set to Solid in the model domains.
Magnus
Hi Massimiliano, The **Electrostriction** multiphyiscs node is not applicable because the **Material type** setting is set to **Nonsolid** in the **Settings** window for **Charge Conservation** in the Electrostatics interface. It should be set to **Solid** in the model domains. Best regards, Magnus
Posted: 2 years ago 23.05.2024, 05:37 GMT-4
Hello, thank you for your suggestion, the domains now are ok, but I still find difficult to plot capacitor deformation. Can you suggest a tutorial? I can find only a lot of piezoelectric examples in the learning center.
Thank you again
Hello, thank you for your suggestion, the domains now are ok, but I still find difficult to plot capacitor deformation. Can you suggest a tutorial? I can find only a lot of piezoelectric examples in the learning center. Thank you again
Posted: 2 years ago 23.05.2024, 06:40 GMT-4
Hello Massimilano,
Plotting deformation is common in structural mechanics models by adding a Deformation subnode to your plot. Its default spatial components are the displacements u, v, and w (in 3D), scaled to show an exaggerated deformation (actual deformations are generally small in comparison to the model geometry). You can change the default scaling if needed.
Hello Massimilano, Plotting deformation is common in structural mechanics models by adding a **Deformation** subnode to your plot. Its default spatial components are the displacements `u`, `v`, and `w` (in 3D), scaled to show an exaggerated deformation (actual deformations are generally small in comparison to the model geometry). You can change the default scaling if needed. Best regards, Magnus
