Nagi Elabbasi
        Facebook Reality Labs
                                10.01.2013, 15:57 GMT-5
                                                    Hi John,
If the temperature is constant it is simpler to not use the heat transfer physics. You can account for the thermal strains using the “Thermal Expansion” sub-node under elastic materials or using the “Initial Stress and Strain” sub-node and manually setting initial strain equal to CTE*(T-T_Ref).
Nagi Elabbasi
Veryst Engineering
                            Hi John,
Nagi Elabbasi
Veryst Engineering
                                14.01.2013, 10:04 GMT-5
                                                    Thanks Nagi,
I have one more question regarding anisotropy, how does COMSOL treat the local and global coordinates in anisotropic models? In anisotropic models is important to be able to impose different local coordinates depending on the orientation of the fibers. Does COMSOL have options for local coordinates in curves and irregular shapes? Where can I find more information about the use of local and global coordinates in anisotropic models?
                            Thanks Nagi,
                                Nagi Elabbasi
                                14.01.2013, 10:29 GMT-5
                                                    For curved geometries you can setup a Base Vector System in the Definitions node and refer to it in the Coordinate System Selection of the material model you are using.  The manuals contain some examples.
Nagi Elabbasi
Veryst Engineering
Nagi Elabbasi
Veryst Engineering
