Magnet - Magnetic and Electric Fields
The below post is related to an archived discussion
I am trying to create a stationary magnet within the Magnetic and Electric Fields setting. I have tried using Ampere's Law and Current Conservation for each pole of the magnet, but keep getting a singular matrix error.
I have seen lots of examples of how to create magnets in the (MF) setting, but I can't figure out how to create it in (MEF).
Any recommendations would be greatly appreciated!
Thanks, Tesla
1 Reply Last Post 14.06.2024, 16:08 GMT-4
Posted: 2 years ago 14.06.2024, 16:08 GMT-4
Updated: 2 years ago 14.06.2024, 16:12 GMT-4
I've attached an example, using the MEF formulation per your request. I don't claim that this is a great model per se, but it doesn't give any computational errors! So take a look at it. FYI, I chose the source of the magnet's field to be a bulk magnetization (rather than try to specify poles). By the way, if you have air or empty space in your problem, be sure to assign it a small but non-zero electrical conductivity!
I've attached an example, *using the MEF formulation* per your request. I don't claim that this is a great model per se, but it doesn't give any computational errors! So take a look at it. FYI, I chose the source of the magnet's field to be a bulk magnetization (rather than try to specify poles). By the way, if you have air or empty space in your problem, be sure to assign it a small but *non-zero* electrical conductivity!
