heat transfer among fluid, solid and porous medium
Posted 24.07.2024, 09:36 GMT-4 Fluid & Heat, Heat Transfer, Porous Media Flow 0 Replies
Heat transfer occurs between a porous plate and a high-temperature fluid on the surface, and another gas is introduced to study the heat transfer in the porous plate. It is found that the temperature of the porous plate in the heat transfer of the porous plate is always at room temperature. How to couple the temperature of fluid solid heat transfer into it? The use of decomposition still cannot solve this problem.
Hello Wang MM
