Effect of sound pressure on refractive index/density
Hello fellow Comsol users,
Most of my experience comes from structural mechanics and fracture and would like to ask a little help regarding pressure acoustics.
The presence of high and low pressure in air will change it's refractive index due to a change in the density. I would like to model this change in refractive index, but am a little lost.
Could anyone tell me how I could go about modelling/solving for a change in material property?
I am using a time dependant pressure model in air. Within the materials section I can see that the density is a function of temperature and pA [which I assume to be absolute pressure], but when I plot the change in density it says that there is no change in density even if there is a change in pressure.
I'm sorry if this question sounds a little dumb, I'm sure that I am just being stupid today.
Also, I have had a look at the forum and a little in the documentation but could not find anything to help.
Anyone have some ideas out there? I would greatly appreciate your help.
Rob
6 Replies Last Post 03.05.2013, 14:32 MESZ
Posted: 1 decade ago 25.01.2013, 11:33 MEZ
You could try to make your material property be a function of your own paramter, lets call it "pressure"
I am using a time dependant pressure model in air. [...]
I am not very good at time dependent models (yet) so you could try to do a frequency domain analysis and use your "pressure" parameter in a parametric sweep. Then you might be able to plot the change in density.
Hope this helps, I have not tried my solution in this specific case, but I have made similar solution using this technique.
/RVN
[QUOTE] Could anyone tell me how I could go about modelling/solving for a change in material property? [/QUOTE] You could try to make your material property be a function of your own paramter, lets call it "pressure" [QUOTE] I am using a time dependant pressure model in air. [...] [/QUOTE] I am not very good at time dependent models (yet) so you could try to do a frequency domain analysis and use your "pressure" parameter in a parametric sweep. Then you might be able to plot the change in density. Hope this helps, I have not tried my solution in this specific case, but I have made similar solution using this technique. -- /RVN
Posted: 1 decade ago 09.04.2013, 15:41 MESZ
Hi all
can you tell me how can i make my model (RF) density dependent (acoustics) through refractive index to solve the scattered wave in RF ?
Best regrads
Hi all can you tell me how can i make my model (RF) density dependent (acoustics) through refractive index to solve the scattered wave in RF ? Best regrads
Posted: 1 decade ago 15.04.2013, 13:45 MESZ
Dear RVN
please could you tell me how can i make the density of the elastic medium : time dependent to get the variation in refractive index of the medium, i tried the time dependent with the elastic mode but i get a fixed density value.
Best regards
Dear RVN please could you tell me how can i make the density of the elastic medium : time dependent to get the variation in refractive index of the medium, i tried the time dependent with the elastic mode but i get a fixed density value. Best regards
Posted: 1 decade ago 03.05.2013, 08:29 MESZ
Dear RVN
Best regards
I made a crude model for you. I am assuming you have the Acoustics module, so take a look under the Pressure Acoustics, Frequency Domain node. Go to Pressure Acoustics Model 1 and note that I choose user defined density (as opposed to "from material"). The numbers I input have no significance, you can choose what suits your needs. The same goes for the sine function I used, use whatever you need.
Hope this helps
/RVN
[QUOTE] Dear RVN please could you tell me how can i make the density of the elastic medium : time dependent to get the variation in refractive index of the medium, i tried the time dependent with the elastic mode but i get a fixed density value. Best regards [/QUOTE] I made a crude model for you. I am assuming you have the Acoustics module, so take a look under the Pressure Acoustics, Frequency Domain node. Go to Pressure Acoustics Model 1 and note that I choose user defined density (as opposed to "from material"). The numbers I input have no significance, you can choose what suits your needs. The same goes for the sine function I used, use whatever you need. Hope this helps -- /RVN
Posted: 1 decade ago 03.05.2013, 11:19 MESZ
Thank you very much for taking the time out to do that for me.
I very much appreciate it.
I can not however open the attached file as it says that it was created in a later version of Comsol, which is odd as I have the latest version installed.
Version, 4.3.0.233
Could you tell me if this is the same version you are using?
Rob
Hi, Thank you very much for taking the time out to do that for me. I very much appreciate it. I can not however open the attached file as it says that it was created in a later version of Comsol, which is odd as I have the latest version installed. Version, 4.3.0.233 Could you tell me if this is the same version you are using? Rob
Posted: 1 decade ago 03.05.2013, 14:32 MESZ
Dear RVN
thanks allot for your attention, i can not open the model now and when i open it i will contact with you, once again i want to appreciate your efforts to help me, i wish you all the best for you.
Best Regards
Hassanain
Dear RVN thanks allot for your attention, i can not open the model now and when i open it i will contact with you, once again i want to appreciate your efforts to help me, i wish you all the best for you. Best Regards Hassanain
