Modify field variable (Pressure)
Posted 19.08.2024, 11:48 GMT-4 LiveLink for MATLAB, Modeling Workflow, Physics Interfaces 0 Replies
Hello, I want to modify a pressure value at a specified node and use it as the initial value for the stabilized Convection-Diffusion Equation. I can access the field data in Livelink for MATLAB through: pd = mpheval(model, 'p0', 'dataset', 'dset1');
I changed the pressure value as follows:
p0_modi = pd;
p0_modi.d1(1,1) = 3;
Since I want to use the modified p0 ("p0_modi.d1"), I tried to set it again through: model.variable('var17').set('p0', p0_modi.d1);
However, due to the unacceptable data type for the .set function, it doesn't work. How can I use "p0_modi" for the p0 variable?
Hello Heejae Jang
