Sharp Fluid-Fluid Interface
I’m new to COMSOL, and I was hoping someone here would be able to help me. I am trying to model fluid displacement in a pipe. I could use the two-phase flow module, but I don’t need that level of precision for my application and it seems to greatly increase computation time. I really just need a perfectly sharp interface, and even assuming plug flow would be sufficient for now. Is there a way to implement this? Thanks!
2 Replies Last Post 01.02.2013, 16:34 MEZ
Posted: 1 decade ago 01.02.2013, 06:55 MEZ
make a cylinder for your liquid, the external cylindrical surface is your "sharp" I/F or didn't I catch your right ?
if you want to model the "solid" wall and the fluid, make a cylinder and add a thin "layer" for the wall
Hi make a cylinder for your liquid, the external cylindrical surface is your "sharp" I/F or didn't I catch your right ? if you want to model the "solid" wall and the fluid, make a cylinder and add a thin "layer" for the wall -- Good luck Ivar
Posted: 1 decade ago 01.02.2013, 16:34 MEZ
You could use two phase flow-ALE module to simulate the oil displacement; the other options are level-set or phase-field. If you do not expect large deformations or topological changes then ALE could be used. You may also want to read the following:
www.comsol.com/support/knowledgebase/1025/
Good Luck.
You could use two phase flow-ALE module to simulate the oil displacement; the other options are level-set or phase-field. If you do not expect large deformations or topological changes then ALE could be used. You may also want to read the following: http://www.comsol.com/support/knowledgebase/1025/ Good Luck.
