I have discovered a potential bug
After adding the two physics interfaces for mass transfer in porous media (tds) and solid mechanics(solid), I found that the hygroscopic expansion module(hs1) cannot select the object from the multiphysics point. It seems to be a clear bug.
However, by replacing the physical field of mass transfer in porous media with the physical field of mass transfer, the problem is solved naturally
3 Replies Last Post 22.10.2024, 00:43 GMT-7
Posted: 2 years ago 16.10.2024, 01:02 GMT-7
Thanks for reporting. We have verified the error you have described, and will release a correction as soon as possible.
Henrik Sönnerlind
COMSOL
Posted: 2 years ago 16.10.2024, 23:46 GMT-7
Thank you so much, and I look forward to hearing this great news soon.
>Thanks for reporting. We have verified the error you have described, and will release a correction as soon as possible. Thank you so much, and I look forward to hearing this great news soon.
Posted: 2 years ago 22.10.2024, 00:43 GMT-7
The correction will be included in version 6.3. This is the next major version, and it will be released soon.
Henrik Sönnerlind
COMSOL
