Jeff Hiller
COMSOL Employee
1 year ago
31.01.2025, 17:24 GMT-5
Hi Florian,
There are at least two possibilities:
- you somehow did not permit heat transfer between the two physics
- heat transfer is happening but at a slow rate and you are not running the simulation long enough for it to be noticeable
In any case, instead of performing a full-fledged CFD simulation in the pipe, I would recommend you consider the approach illustrated by this tutorial if your license includes the optional Pipe Flow Module. That approach solves much quicker and uses much less memory. You can check whether your license includes the Pipe Flow Module by going to File > Licensed and Used Products.
Jeff Hiller
Hi Florian,
In any case, instead of performing a full-fledged CFD simulation in the pipe, I would recommend you consider the approach illustrated by [this tutorial](https://www.comsol.com/model/cooling-of-an-injection-mold-12371) if your license includes the optional Pipe Flow Module. That approach solves much quicker and uses much less memory. You can check whether your license includes the Pipe Flow Module by going to File > Licensed and Used Products.
Florian Ferri
Thermique, Energétique & Mécanique
12 months ago
02.02.2025, 13:27 GMT-5
Hi Florian,
Hello Jeff,
Thank you for you answer.
My simulation lasted 1 hour, tomorrow I will try for longer to see what happens.
Unfortunately, I already wanted to try out the Pipe Flow module, but my school's licence does not offer it.
>Hi Florian,
>Best,
>Jeff
Hello Jeff,
