biosensor
hi sir,i am currently working on microcantilever beam based biosensor,and i want to know about the piezoelectric module and how to incorporate BC in microcantilever,
3 Replies Last Post 26.02.2013, 18:09 MEZ
Posted: 1 decade ago 25.02.2013, 19:57 MEZ
the principle remins the same for all physics: all dependent variables require minimum 1 or 2 BC to define the constants for the equation integrations. So go through all yourphysics, and all your dependent variables and chack that the BC sem coherent. The rest depends on your model and ho you assemble it.
Hi the principle remins the same for all physics: all dependent variables require minimum 1 or 2 BC to define the constants for the equation integrations. So go through all yourphysics, and all your dependent variables and chack that the BC sem coherent. The rest depends on your model and ho you assemble it. -- Good luck Ivar
Posted: 1 decade ago 26.02.2013, 17:09 MEZ
how to calculate resonant frequency for microcantilever beam
Posted: 1 decade ago 26.02.2013, 18:09 MEZ
do an eigenfrequency study. If your beam is "pre-stressed" check how to do first a stationary stress case, then use that as linearisation point for the eigenfrequency solver. There is for certain physics a predefined "pre stressed eigenfrequency" solver possibility
Hi do an eigenfrequency study. If your beam is "pre-stressed" check how to do first a stationary stress case, then use that as linearisation point for the eigenfrequency solver. There is for certain physics a predefined "pre stressed eigenfrequency" solver possibility -- Good luck Ivar
