Need Help with Simulating Thermal Stresses in a Layered Plate
Posted 04.03.2013, 14:17 GMT-5 MEMS & Nanotechnology, MEMS & Piezoelectric Devices Version 4.3a 4 Replies
Hi Experts,
I kept running into this message:
Failed to find a solution.
System matrix is zero.
I wasn't sure what exactly went wrong in my model. I'd really appreciate it if someone can help me out. I've been stuck with this same problem for a long time. Thanks a lot! I have attached my model here as well.
Below are the steps I went through... ( The idea is that I wanted to see the thermal stresses on two layers of plates as they go through temperature drop, given the values of young's modulus, poisson's ratio, thermal expansion and dimentions of the geometry, which is square in my case)
1 Go to the Model Wizard window.
2 Click the 3D button.
3 Click Next.
4 In the Add physics tree, select Structural Mechanics>Solid Mechanics (solid).
5 Click Add Selected.
6 In the Model Builder window, right-click Global Definitions and choose Parameters.
7 Go to the Settings window for Parameters.
8 Locate the Parameters section. In the Parameters table, enter the following settings:
NAME EXPRESSION DESCRIPTION
Tcontractive 100[degC] Initial temperature at stress free stage
Tpassive 20[degC] Final temperature after temperature drop
9 In the Model Builder window, right-click Model 1>Geometry 1 and choose block.
10 Go to the Settings window for block
11 Locate the Size section. In the Height edit field, type 1.
12 In the Width edit field, type 1
13 Click the Build All button.
14 In the Model Builder window, right-click Geometry 1 and choose block.
15 Go to the Settings window for Block
16 Locate the Size section. In the Width edit field, type 1.
17 In the Height edit field, type 1.
18 Locate the Position section. In the z edit field, type 1.
19 Click the Build All button.
20 In the Model Builder window, right-click Model 1>Solid Mechanics and choose Rename.
21 Go to the Rename Solid Mechanics dialog box and type Two Layers in the New name edit field.
22 Click OK.
23 Select Domains 1 and 2 only.
In the Model Builder window, expand the Model 1>Two Layers .
24 Right-click Linear Elastic Material Model 1 and choose Thermal Expansion.
25 Go to the Settings window for Thermal Expansion.
26 Locate the Thermal Expansion section. In the Tref edit field, type Tcontractive.
27 Locate the Model Inputs section. In the T edit field, type Tpassive.
In the Model Builder window, right-click Two Layers and choose Points>Fixed Constraint.
28 Select Vertex 4 only.
29 In the Model Builder window, right-click Two Layers and choose Points>Prescribed
30 Select Vertex 8 only.
31 Go to the Settings window for Prescribed Displacement.
32 Locate the Prescribed Displacement section. Select the Prescribed in y direction check box.
33 In the Model Builder window, right-click Model 1>Materials and choose Material.
34 Right-click Material 1 and choose Rename.
35 Go to the Rename Material dialog box and typePassive Layer in the New name edit field.
36 Click OK.
37 Go to the Settings window for Material.
38 Locate the Geometric Entity Selection section. From the Selection list, select Manual.
39 Click Clear Selection.
40 Select Domain 1 only.
41 Locate the Material Contents section. In the Material contents table, enter the following settings:
PROPERTY NAME VALUE
Young's modulus E 2.15e11
Poisson's ratio nu 0.3
Density rho 1000
Thermal expansion coefficient alpha 6e-6
42 In the Model Builder window, right-click Materials and choose Material.
43 Right-click Material 2 and choose Rename.
44 Go to the Rename Material dialog box and type contractive layerin the New name edit
field.
45 Click OK.
46 Select Domain 2 only.
47 Go to the Settings window for Material.
48 Locate the Material Contents section. In the Material contents table, enter the following settings:
PROPERTY NAME VALUE
Young's modulus E 1.3e11
Poisson's ratio nu 0.28
Density rho 1000
Thermal expansion coefficient alpha 3e-6
In the Model Builder window, right-click Model 1>Mesh 1 and choose Mapped.
49 In the Model Builder window, click Size.
50 Go to the Settings window for Size.
51 Locate the Element Size section. From the Predefined list, select Extra fine.
52 Click the Build All button.
53 In the Model Builder window, right-click Study 1 and choose Compute
3 Click Next.
22 Click OK.
36 Click OK.
PROPERTY NAME VALUE
Density rho 1000
field.
45 Click OK.
PROPERTY NAME VALUE
Density rho 1000
4 Replies Last Post 04.11.2013, 17:51 GMT-5
