Absorbing boundary condition for transient wave propagation problem
Hi!
I am wondering if I can define an absorbing boundary condition for a transient ultrasonic wave propagation problem (let's say in a 2D plane strain transient module). The option certainly doesn't come up in the boundary conditions pulldown menu. I wonder if there is a trick.
Thanks!
Deb
8 Replies Last Post 06.09.2017, 12:56 MESZ
Posted: 1 decade ago 04.03.2013, 21:23 MEZ
use PML
use PML
Posted: 1 decade ago 05.03.2013, 00:49 MEZ
What you are looking for is the "Low-Reflecting Boundary" which should be available for 2D Plain Strain as long as you have either the Structural Mechanics, MEMS or Acoustics Module. A PML can only be used in frequency domain analyses.
Henrik
Hi, What you are looking for is the "Low-Reflecting Boundary" which should be available for 2D Plain Strain as long as you have either the Structural Mechanics, MEMS or Acoustics Module. A PML can only be used in frequency domain analyses. Regards, Henrik
Posted: 9 years ago 17.02.2016, 00:09 MEZ
Hi Henrik,
How do you apply PML in structural mechanics module? I am doing a modal analysis and only see 'Low reflection boundary' option.
Gyani
Hi Henrik, How do you apply PML in structural mechanics module? I am doing a modal analysis and only see 'Low reflection boundary' option. Thanks, Gyani
Posted: 9 years ago 17.02.2016, 08:19 MEZ
You select a domain as PML under Component->Definitions.
Regards.
Henrik
Hi, You select a domain as PML under Component->Definitions. Regards. Henrik
Posted: 9 years ago 18.02.2016, 01:19 MEZ
Thanks very much!
Thanks very much!
Posted: 9 years ago 27.04.2016, 06:41 MESZ
Henrik
Hi Henrik,
It is true that the PML is only available in frequency domain analyses. Could you please explain the reason? And what should I deal with the reflection by the boundary if I work on the transient process, like pulse scattering? Thank you very much.
Shengli
[QUOTE] Hi, What you are looking for is the "Low-Reflecting Boundary" which should be available for 2D Plain Strain as long as you have either the Structural Mechanics, MEMS or Acoustics Module. A PML can only be used in frequency domain analyses. Regards, Henrik [/QUOTE] Hi Henrik, It is true that the PML is only available in frequency domain analyses. Could you please explain the reason? And what should I deal with the reflection by the boundary if I work on the transient process, like pulse scattering? Thank you very much. Best, Shengli
Posted: 8 years ago 06.09.2017, 12:22 MESZ
I can't found the PML option even i selected Definition under the Component
Denny Bhatara
Physics Departement, Faculty of Mathematic and Nature Science
Bogor Agriculture University, Indoesia (ID)
Hi I can't found the PML option even i selected Definition under the Component -- Denny Bhatara Physics Departement, Faculty of Mathematic and Nature Science Bogor Agriculture University, Indoesia (ID)
Posted: 8 years ago 06.09.2017, 12:56 MESZ
Denny Bhatara
Solved. Just right click on the Defiinition (Component -> Definition -> Right Click).
Denny Bhatara
[QUOTE] Hi I can't found the PML option even i selected Definition under the Component -- Denny Bhatara Physics Departement, Faculty of Mathematic and Nature Science Bogor Agriculture University, Indoesia (ID) [/QUOTE] Solved. Just right click on the Defiinition (Component -> Definition -> Right Click). -- Denny Bhatara Physics Departement, Faculty of Mathematic and Nature Science Bogor Agriculture University, Indoesia (ID)
