Excavation process - time dependent
I am trying to model a real-time excavation of a borehole. Assuming that at the time t = 0, the drilling begins and at time t = 1 day, the tunnel advancement is 1 m (drilling velocity = 1m/day). Imagine that I build a cylindrical mesh inside a cubbic mesh. The outer surface of the cylinder is where the drilling is initiated. The drilling advancement is along the cylinder. What the boundary conditions I should use in the outer surface of the cylinder to simulate the drilling process? Thanks.
3 Replies Last Post 21.03.2013, 07:38 MEZ
Posted: 1 decade ago 20.03.2013, 16:44 MEZ
do you know this model from the COMSOL "showroom"?
www.comsol.com/showroom/documentation/model/9747/
Even if you could not open it in case you do not have a license for the required modules, the documentation files are quite interesting. They explain how to implement a stepwise excavation advance using a parametrized geometry based on parameters from a parametric sweep.
Maybe this model and the according documentation are of interest for your problem?
Juergen
Hi, do you know this model from the COMSOL "showroom"? http://www.comsol.com/showroom/documentation/model/9747/ Even if you could not open it in case you do not have a license for the required modules, the documentation files are quite interesting. They explain how to implement a stepwise excavation advance using a parametrized geometry based on parameters from a parametric sweep. Maybe this model and the according documentation are of interest for your problem? Best regards, Juergen
Posted: 1 decade ago 20.03.2013, 16:49 MEZ
I have looked through the example you gave me. The example is steady case but I want to expand to transient case. Other than that, the example is quite complex so I want to simplify it. Anyway, thanks for your suggestion.
Posted: 1 decade ago 21.03.2013, 07:38 MEZ
parametrized geometry also works in transient studies.
You can combine a parametric sweep and a transient solver.
I did some similar models quite a while ago.
The tricky thing in my case was to use the solution of the last parametric sweep step as initial values for the next parametric sweep step.
Juergen
Hi, parametrized geometry also works in transient studies. You can combine a parametric sweep and a transient solver. I did some similar models quite a while ago. The tricky thing in my case was to use the solution of the last parametric sweep step as initial values for the next parametric sweep step. Best regards, Juergen
