Piezoresistive Coefficients
I want to find out the sensitivity of my piezoresitive cantilver beam. In order to do that, based on the equations, I should have the piezoresistive coefficient (Pi-1):
Delta-R/R=(PI-1)*maximum surface stress
In the materiel properties of polysilicon i have a matrix for piezoresitive coupling factor which I believe should give me the coefficient that I need to use in the equation. However, there is a "sigma" parameter in that I do not know what is its value, since i did not define that.
Can anyone help me with this?
here is the matrix that is defined by comsol :
{58.8e-11[1/Pa]/sigma0(nd[m^3])[S/m], -27.2e-11[1/Pa]/sigma0(nd[m^3])[S/m], 58.8e-11[1/Pa]/sigma0(nd[m^3])[S/m], -27.2e-11[1/Pa]/sigma0(nd[m^3])[S/m], -27.2e-11[1/Pa]/sigma0(nd[m^3])[S/m], 58.8e-11[1/Pa]/sigma0(nd[m^3])[S/m], 0, 0, 0, 85.9e-11[1/Pa]/sigma0(nd[m^3])[S/m], 0, 0, 0, 0, 85.9e-11[1/Pa]/sigma0(nd[m^3])[S/m], 0, 0, 0, 0, 0, 85.9e-11[1/Pa]/sigma0(nd[m^3])[S/m]}
Best Regards
Bahar
3 Replies Last Post 14.01.2014, 13:52 MEZ
Posted: 1 decade ago 11.04.2013, 08:06 MESZ
Hi Bahar
if you open up all the material nodes and sub-nodes you will find the analytical definition of "sigma0" (you might need to turn on the options preferences show advanced or all (COMSOL hides some of it's complexity ba default, I finally run with all open, much more fun and interesting to learn about ;)
Hi Bahar if you open up all the material nodes and sub-nodes you will find the analytical definition of "sigma0" (you might need to turn on the options preferences show advanced or all (COMSOL hides some of it's complexity ba default, I finally run with all open, much more fun and interesting to learn about ;) -- Good luck Ivar
Posted: 1 decade ago 14.01.2014, 13:51 MEZ
Hello Ivar,
Do you know what this nd = (Number density) parameter represents.
the formula used for conductivity (Sigma0) looks like fitting function based on the electron charge (e_const).
Does (nd) refer to number of electrons (or free charges). Does it have any relation with the doping concentration defined in the piezoresistive or conductive parts?
Mohamed
Hello Ivar, Do you know what this nd = (Number density) parameter represents. the formula used for conductivity (Sigma0) looks like fitting function based on the electron charge (e_const). Does (nd) refer to number of electrons (or free charges). Does it have any relation with the doping concentration defined in the piezoresistive or conductive parts? Thanks Mohamed
Posted: 1 decade ago 14.01.2014, 13:52 MEZ
Hello Ivar,
Mohamed
