Moving mesh example
Is there any example of using moving mesh with a pdf guideline?
I need to model a moving magnet next to a coil and calculate the induced voltage!
8 Replies Last Post 15.10.2014, 13:23 MESZ
Posted: 1 decade ago 18.04.2013, 17:30 MESZ
Posted: 1 decade ago 18.04.2013, 17:51 MESZ
Thank you so much.
I am still working on your example to understand what it is trying to do. A quick question: in the prescribed deformation, domains 5 and 6 are assigned to have a prescribed mesh deformation in z direction. NA later on in prescribed mesh displacement 4 we assign the one of the boundaries of domains 5 and 6 to have the same prescribed z displacement, why?
Thank you so much. I am still working on your example to understand what it is trying to do. A quick question: in the prescribed deformation, domains 5 and 6 are assigned to have a prescribed mesh deformation in z direction. NA later on in prescribed mesh displacement 4 we assign the one of the boundaries of domains 5 and 6 to have the same prescribed z displacement, why?
Posted: 1 decade ago 25.02.2014, 22:05 MEZ
can u share me with thatexample
Posted: 1 decade ago 27.02.2014, 03:22 MEZ
Hey,
Sure, I will share it with you and I made this working. BUt first I have to remove soem of the parts which will be our design. So If I forget to do this with in the next days, remind me.
Ehsan
Hey, Sure, I will share it with you and I made this working. BUt first I have to remove soem of the parts which will be our design. So If I forget to do this with in the next days, remind me. Thanks, Ehsan
Posted: 1 decade ago 15.06.2014, 15:11 MESZ
hi there, I am also stuck with the moving mesh of a permanent magnet . can you send me a copy of the moving mesh example please ? thx a lot!
Posted: 1 decade ago 23.06.2014, 14:25 MESZ
These days I tried to use the moving mesh program. But I found a problem.
When my model has a small work distance (i.e., we need less remeshing times), the moving mesh can work very well, but when it comes to a big model. It doesn't work..
So i really want to know if I have a wrong seeting?
Plz be kind share me your example.
Thank you so much.
Feifan
These days I tried to use the moving mesh program. But I found a problem. When my model has a small work distance (i.e., we need less remeshing times), the moving mesh can work very well, but when it comes to a big model. It doesn't work.. So i really want to know if I have a wrong seeting? Plz be kind share me your example. Thank you so much. Feifan
Mohammad Uzzal Hossain Joardder
Posted: 1 decade ago 18.09.2014, 05:14 MESZ
I ma doing moving mesh of food due to heat and mass transfer.
Do you have any moving mesh example with PDF guideline.
Thank you in advance.
King regards,
Mohammad Joardder
Hi, I ma doing moving mesh of food due to heat and mass transfer. Do you have any moving mesh example with PDF guideline. Thank you in advance. King regards, Mohammad Joardder
Posted: 1 decade ago 15.10.2014, 13:23 MESZ
Arthur,
Can you send me the example of the moving mesh model? I am working on a similar motion described in the thread and would like something to follow.
Thank you
Arthur, Can you send me the example of the moving mesh model? I am working on a similar motion described in the thread and would like something to follow. Thank you
