error 6250 ???
Can I know what is this error?
I do not understand what that means "Global scope"
I check all, but I can't find a fault
amine
1 Reply Last Post 05.03.2010, 09:24 GMT-5
Posted: 1 decade ago 05.03.2010, 09:24 GMT-5
when I get such errors, were at least I have the variable name, then I go through the variables to locate the specific one and try to understand from where it could come.
Often its a typo in a name of a constant or some formula used to define thevariable, or it could be a variable name conflict (i.e. you have a constant with the same name) or the specific application set up is not fully defined
Hi when I get such errors, were at least I have the variable name, then I go through the variables to locate the specific one and try to understand from where it could come. Often its a typo in a name of a constant or some formula used to define thevariable, or it could be a variable name conflict (i.e. you have a constant with the same name) or the specific application set up is not fully defined Good luck Ivar
