Jeff Hiller
        COMSOL Employee
                                26.04.2013, 11:02 GMT-4
                                                    Your model is ill-posed because nothing is preventing the geometry from sliding in the z direction. You can prevent that by imposing a prescribed displacement of 0 in the z direction at point 5 for instance.
Note also that the file you attached is not applying a pressure but rather a vertical force to boundaries 6 and 7.
                                26.04.2013, 11:04 GMT-4
you have not put any pressure but a vertical load, that means your part is accelerated vertically with no limits. You should ensure your model is restrained in all 6 doF (at least 3 for 2D axi), you have restricted 2 of3 one remains fully free.
if you rely only on forces, your system might run off by numerical integration on small errors, you need some "anti-windup" concept here to, as used in control theory, for that a simple "soft enough" spring (along Z motion here) well might do the job
                                26.04.2013, 11:09 GMT-4
                                                    Hi Jeff
Thank you. I agree about the pressure, sorry my mistake.
Concerning the boundary 5, I thouhgt it could be moving in the z direction like the 2 and 4 boundaries that are free. I'm not sure if i understand that!
                            Hi Jeff
                                Jeff Hiller
        COMSOL Employee
                                26.04.2013, 12:04 GMT-4
                                                    Hi Nick,
I am talking about point 5, not boundary 5.
I suggested prescribing that point's vertical displacement to zero (rather than any other point's) because it will get you a nice symmetric solution.
                            Hi Nick,
                                26.04.2013, 15:37 GMT-4
                                                    thanks it works perfectly!
