Messages: Failed to initialize physics interface
When I try to load a COMSOL file into Python using "client = mph.start()" and "model = client.load("./test.mph")", I encounter the following error. Some files load without any issues, while others fail. I suspect it is not a license or version problem, but rather an issue caused by specific settings within the file itself. "Even a blank file with no components, only physics(heat transfer in solids) added causes an error when loading.
Traceback (most recent call last): File "java.lang.Thread.java", line 0, in java.lang.Thread.run
Exception: Java Exception
com.comsol.util.exceptions.com.comsol.util.exceptions.FlException: Exception: com.comsol.util.exceptions.FlException: Failed to initialize physics interface. Messages: Failed to initialize physics interface.
1 Reply Last Post 18.11.2025, 11:39 GMT-5
Hello Wonbin Song
Posted: 12 months ago 18.11.2025, 11:39 GMT-5
We have encountered this same issue with COMSOL 6.3's Java API. When calling com.comsol.model.util.ModelUtil.load with a particular file, it throws an exception and fails to load the file. I have included a stack trace for the exception that is thrown. This does not happen with all COMSOL files. It has only been a particular file causing the problem. The only noteworthy thing I can think of is that it uses Unicode characters for most of the descriptions.
We have encountered this same issue with COMSOL 6.3's Java API. When calling `com.comsol.model.util.ModelUtil.load` with a particular file, it throws an exception and fails to load the file. I have included a stack trace for the exception that is thrown. This does not happen with all COMSOL files. It has only been a particular file causing the problem. The only noteworthy thing I can think of is that it uses Unicode characters for most of the descriptions.
