Extracting data in 3d format
So far, I have been extracting abs(emwHz) values for given parameter in a 2D cutplane in my loop antenna model. I would like to extract it in a 3D grid format.
However, most methods of trying a grid 3D dataset has resulted in errors, where Hz is an undefined variable, like as shown below.
"Undefined variable. - Variable: comp1.emw.Hz - Global scope Failed to evaluate expression. - Expression: comp1.emw.Hz"
Is there a way to overcome this error, or if not, to obtain Hz values in a 3d format?
2 Replies Last Post 29.08.2025, 06:55 GMT-4
Posted: 10 months ago 28.08.2025, 21:25 GMT-4
I suggest you post your .mph file to the forum.
Posted: 10 months ago 29.08.2025, 06:55 GMT-4
I have attached the file. I have only left the solution, datasets needed and the derived values i tried to use. Unfortunately, I dont have access to the latest version of COMSOL so this is the best i could work with.
