Robert Koslover
Antennas, Waveguides, Electromagnetics
11 months ago
11.09.2025, 10:05 GMT-4
Updated:
11 months ago
11.09.2025, 10:08 GMT-4
You appear to have placed conducting boundaries around ALL the edges of your lumped ports. That is not the right way. You are shorting out the ports -- look at your settings under Perfect Electric Conductor 1 and Perfect Electric Conductor 2. The electric field in each rectangular port should travel perpendicularly from one conducting edge of a port to the opposite, parallel edge of the port. It should not travel along a conducting edge, since that would short out the port.
You appear to have placed conducting boundaries around ALL the edges of your lumped ports. That is not the right way. You are shorting out the ports -- look at your settings under *Perfect Electric Conductor 1* and *Perfect Electric Conductor 2*. The electric field in each rectangular port should travel perpendicularly from one conducting edge of a port to the opposite, parallel edge of the port. It should not travel *along* a *conducting* edge, since that would short out the port.
11 months ago
11.09.2025, 12:10 GMT-4
thank you for such fast response, I will correct this
11 months ago
12.09.2025, 12:19 GMT-4
Updated:
11 months ago
12.09.2025, 14:20 GMT-4
Hi, I want to run the simulation of CPW resonator with capacitively coupled with lamped port . But there I can not generate the S21 plot, can anyone help...
