Edgar J. Kaiser
Certified Consultant
12 months ago
11.11.2025, 19:09 MEZ
Hi Imke,
the skin effect results from induction currents in the conductor, so ec-physics cannot account for it.
You need mf in case the structure is much smaller than the wavelength or emw if the structure is bigger than 1/10 of the wavelength. This a coarse rule of thumb.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Imke,
Cheers
Edgar
12 months ago
12.11.2025, 11:11 MEZ
Hi Edgar,
Thanks for your reply. I understand that EC cannot capture the skin effect and that I should use MF or EMW depending on the frequency.
In my case, I would like the current to enter at a single point at one end of a cylinder and exit at a single point at the other end, rather than being distributed over the entire surface.
Could you explain how to set up MF in COMSOL to specify exact input and output points for the current, without using a volume or surface current density? Is there a way to emulate a point injection and collection of current in MF?
Thanks in advance!
Hi Edgar,
Thanks in advance!
Edgar J. Kaiser
12 months ago
12.11.2025, 15:29 MEZ
Hi Imke,
I recommend to have a look into the application library to learn about how to set up single conductor coils in mf or ports in emw. Point connections are mostly not recommended because they may result in singularities.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Hi Imke,
Cheers
Edgar
