Modelling Inflation
Hello, I am hoping to model how an air bladder inflates and how pressure changes. I am trying to create a weight-bearing inflatable and need a way to model this process. I am super lost with where to start so any help or advice would be greatly appreciated.
2 Replies Last Post 18.11.2025, 06:30 GMT-6
Posted: 8 months ago 17.11.2025, 11:48 GMT-6
Hi Ella,
in many cases the best start is to perform an extensive search, e.g. in the application library, the application gallery, in the COMSOL blog etc. You may find something similar to your requirements. Play with it and modify it to your needs. You may still encounter issues but then you can come up with more specific questions.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Ella, in many cases the best start is to perform an extensive search, e.g. in the application library, the application gallery, in the COMSOL blog etc. You may find something similar to your requirements. Play with it and modify it to your needs. You may still encounter issues but then you can come up with more specific questions. Cheers Edgar
Posted: 8 months ago 18.11.2025, 06:30 GMT-6
You could take a look at
https://www.comsol.com/model/inflation-of-a-square-airbag-101921
Henrik Sönnerlind
COMSOL
