Acoustic-Structure Interaction: Modeling Sound Transmission Loss of a Finite Cylindrical Shell
Hi everyone,
I am trying to model the Sound Transmission Loss (STL) through a finite-length, thin-walled circular cylindrical shell in COMSOL Multiphysics and validate it against an analytical paper.
​Here are the specific details of the problem setup:
​Geometry & Physics: A finite-length isotropic cylindrical shell modeled using Love's thin shell theory.
​Acoustic Environment: The shell is excited from the outside by an oblique incident harmonic plane sound wave. The transmitted wave enters an interior anechoic cavity (non-reverberant / inward-traveling waves only).
​Boundary Conditions: The cylinder is Simply Supported (S-S) at both circular ends (v=0, w=0, N_{xx}=0, M_{xx}=0).
​I plan to use the Acoustic-Structure Interaction (Frequency Domain) interface with the Shell module for the structure and Pressure Acoustics for the fluid domains.
Could anyone guide me on the best practices for setting up:
​The Background Pressure Field for an oblique incident plane wave acting on the outer cylindrical surface.
​The Perfectly Matched Layer (PML) or radiation boundary conditions inside the cylinder to properly simulate the anechoic core without artificial reflections.
​The exact constraints in the Shell interface to correctly replicate the Simply Supported conditions for a vibrating shell.
​Any model templates, expressions, or advice on capturing the stiffness, resonance, and mass-controlled regions accurately would be highly appreciated!
Update on my current COMSOL setup and the issue I'm facing:
To give more context, here is what I have already done in my model:
​Geometry: I have modeled a thin finite-length steel cylinder. Around this inner cylinder, I created a larger concentric cylinder domain to apply the Perfectly Matched Layer (PML).
​Material & Domains: Since both ends of the inner finite cylinder are open and the paper assumes air inside and outside, I have assigned Air to the entire domain inside the larger cylinder (which automatically covers both the exterior fluid and the fluid inside the open inner cylinder).
​Physics & Coupling: For the Acoustic-Structure Interaction, I have selected both the inner and outer curved surfaces of the steel cylinder.
​Loading & BCs: I implemented the Simply Supported boundary conditions on the shell edges. To simulate the external oblique plane wave, I applied a Boundary Load as a pressure distribution directly on the outer surface of the inner cylinder.
​The Issue: While the simulation runs and I am getting graphs, the results are not convincing and do not match the analytical curves from the paper. I suspect there might be an issue with how I am applying the oblique plane wave as a manual Boundary Load instead of using COMSOL's built-in Background Pressure Field or Incident Acoustic Fields. Could anyone please point out the flaws in this approach or suggest how to correctly set up the incident plane wave and acoustic-structure coupling for this specific open-ended case?
Please help me, this is the paper link I am trying to get results in COMSOL:
Golzari, M., & Jafari, A. A. (2019). "Sound transmission through truncated conical shells." Applied Acoustics, 156, 186-207.
0 Replies Last Post 08.07.2026, 11:53 MESZ
Hello Rajat Mishra
Reply
