Bug in matlab livelink, 2D cut line 'genpoints'
Posted 05.06.2013, 14:42 GMT-4 Low-Frequency Electromagnetics, Interfacing Version 4.3a 1 Reply
Hi just want to give a heads up to anyone experiencing problems with retrieving data from a 2D cut-line in matlab.
My objective: To get average air gap magnetic field over one pole span, by using 2D cut-line in the middle of the air gap using livelink-matlab.
Problem: Even though the entire model is defined in [mm], and my entire geometry is successfully built, the points defining the 2D-cutline is for some reason defined as [m], so obviously the result from the 2D cut-line is wrong. This is very difficult to detect, since no error is displayed. Also, if the matlab model is saved and opened in Comsol, the 2D cut-line points will be automatically evaluated as [mm], and give correct results.
This is the commandline in matlab defining the points of the cut-line which is evaluated as [m]:
model.result.dataset('cln1').set('genpoints', {'0' '-g/2'; 'tp*r_avg' '-g/2'});
where 'g' [mm] is my air gap , 'tp' [rad] is my pole span , and 'r_avg' [mm] is average radius. (axial flux PM machine)
The only fix I can find is to do like this:
model.result.dataset('cln1').set('genpoints', {'0' '-g/2000'; 'tp*r_avg/1000' '-g/2000'});
I tried this but did not work:
model.result.dataset('cln1').set('genpoints', {'0[mm]' '-g/2[mm]'; 'tp*r_avg[mm]' '-g/2[mm]'});
model.result.dataset('cln1').set('genpoints', {'0[m]' '-g/2[m]'; 'tp*r_avg[m]' '-g/2[m]'});
model.result.dataset('cln1').set('genpoints', {'0[mm]' '-g/2'; 'tp*r_avg' '-g/2'});
_________
If anyone has any other fix than this, please let me know...
Thx
_________
Thx
1 Reply Last Post 24.06.2013, 03:11 GMT-4
