Integrate one Study in another
Posted 12.06.2013, 10:15 MESZ Modeling Tools & Definitions, Parameters, Variables, & Functions, Studies & Solvers Version 4.3a 2 Replies
I am trying to solve a study with a fluid flow problem and an electrochemistry problem. Both studies can be solved by themselves but if I want to solve them together or use the Velocity field of the fluid flow problem in the Electrochemistry problem it doesn't work.
The electrochemistry simulation works if I use a velocity field of (0,v) for the Electrolyte flow in the two "Tertiary Current Distribution, Nernst-Planck" options and the Brinkmann equation works if I do it seperatly.
Now I want to set as Velocity field in the two "Tertiary Current Distribution, Nernst-Planck" the solution from the brinkmann equation (br/fmp1). I solved this in a seperate studie "Study 2". but as a result of "Study 1" the error:
"Failed to find a solution.
Returned solution is not converged."
shows up.
Perhaps I make a mistake with the integration of the results of Study2 in study 1?
Can someone help me with this problem?
Thank you!
Michael
shows up.
Thank you!
Michael
2 Replies Last Post 05.04.2017, 08:50 MESZ
