2 decades ago
12.03.2010, 21:11 MEZ
I do not think you can give an individual element an initial stress, but you can define one for any sub-domain, or you would need to set an initial stress value as a function of rand(x,y) (to be checked), take a look at the "init" tab of the BCs.
You can also do an analysis and save the final state as inital condition for a restart/re-run
To change the stiffness, I beleive you should do as you said, set E to something small (perhaps not true 0)with a bolean condition, take a look at the examples for optimising 2D shapes, there are some good sample cases in there
2 decades ago
12.03.2010, 21:51 MEZ
As a sanity check if i generate a data file full of randomly sampled values then insert them as a data file function (somefn(x,y)) then for initial stress I supply that function. Would that put something like my random state onto the sample or will the interpolation and other steps like that turn it to garbage.
2 decades ago
12.03.2010, 21:59 MEZ
Sorry i just checked it is just rubbish that is generated.
2 decades ago
12.03.2010, 22:16 MEZ
shure? did you do an "solve get initial value" ?
because if I put a displacement initial value of the type v=0.001[1/m]*x^2 for a simple 2D canteliever I get a initial quadratic deformation, so why not for stress ? (I cannot check as I have no ccess to COMSOL just now ;)
2 decades ago
13.03.2010, 13:06 MEZ
I think its because my data is very random when comsol tries to interpolate from one random value to the other it creates points that are not from the sampled distribution and makes it more noisy, while the function you are using is quite smooth.
