sine waveform
Hello
Please help me, my model is a electrode in a cylinder of tissue. i want to put a AC voltage on the electrode.
i defined sine waveform (wv1) from (global definitions> functions> waveform)
Now i want to put (wv1) as the voltage on the electrode boundary
so i put " V0 = wv1" in electric currents node (ec )> electric potential 1 setting window
but when i put (wv1) in electric potential node in electric current node (ec) as (V0 = wv1), the line turns orange and the solver gives me an error saying "unknown variable wv1"
thanks
1 Reply Last Post 29.08.2013, 10:09 MESZ
Posted: 1 decade ago 29.08.2013, 10:09 MESZ
When I simulate cyclic voltammetry, I define a variable TH which is valid on the electrode surface:
Name Expression
TH exp(f*(Ei+v*t-2*v*flc1hs(t-ts,.01)*(t-ts)))
and Ei, v, ts are defined parameters. Hence, define a variable, not a function.
When I simulate cyclic voltammetry, I define a variable TH which is valid on the electrode surface: Name Expression TH exp(f*(Ei+v*t-2*v*flc1hs(t-ts,.01)*(t-ts))) and Ei, v, ts are defined parameters. Hence, define a variable, not a function.
