16.09.2013, 14:11 MESZ
I need some help, I want to model a 3d shielded room 12mm thick (2mx2mx3m) placed in real magnetic field (geomagnetic, frequency range 0-300Hz). When I select the AC/DC model, magnetic field, frequency domain, I put the parameter B=50e-6T, then in magnetic field I select magnetic field = B/mu0_const, I receive an error after computation. What is the best way to model the ambient geomagnetic field, To put the shielded room in a cube, a sphere? to put the condition for magnetic field source on the walls of the cube? what I am trying to find is the phase shift of the magnetic field when passing the wall of the shielded room with application in biomagnetism.
please give me a help to finish this small model for some, important for me,
Perhaps you may first read the "submarine" example in AC/DC module, and I think the submarine model which uses the magnetic shielding boundary condition is similar to your magnetic shielding room, for both of them are multi-scaled, ie, the very thin thickness and very large dimensions.
good luck!
[QUOTE]
[/QUOTE]
good luck!
Edgar J. Kaiser
Certified Consultant
16.09.2013, 14:13 MESZ
Hi Anca,
it is often a matter of taste how to choose the geometry of the outer boundary, I like a sphere because it doesn't have sharp edges and corners. You can use a magnetic field boundary to achieve a uniform field inside the boundary (e.g. the sphere). A few more hints:
- The frequency zero gives an error in a frequency domain study, for zero (static field) choose a static study
- Add the 'gauge fixing for A-field' under the Ampere's law node
- Look at the complex field components inside the shield to find the phase shift.
- Avoid sharp edges and corners in the geometry of the shield.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
Hi Anca,
Cheers
Edgar
Edgar J. Kaiser
16.09.2013, 14:21 MESZ
Thank you, I am runing the model now, but about the frequency, In the magnaetic field no currents I can't varry the frequency, and the phase inside the shield varries with the shield thick and frequency of the applied magnetic field....
Edgar J. Kaiser
19.09.2013, 16:23 MESZ
Anca,
you have to use the mf. physics for that, mfnc. doesn't offer the frequency domain study.
Cheers
Edgar
Edgar J. Kaiser
Anca,
Cheers
Edgar
Edgar J. Kaiser
