Hello Denis Maus
31.03.2014, 15:52 MESZ
did you find an answer for your question? I also working on Mac OS and would very much like to be able to open multiple comsol models at the same time.
//Ellen
//Ellen
09.04.2014, 09:18 MESZ
no, unfortunately i did not found a solution.
26.06.2014, 15:58 MESZ
You can run a new instance by using the following command in the Terminal.
open -na "COMSOL Multiphysics.app"
Procedure to open from COMSOL installation directory:
1.- Open Terminal
2.- Go to your COMSOL Directory example: "cd /Applications/COMSOL44"
3.- Use the command : "open -n "COMSOL Multiphysics.app"
Done a new instance should be running. You can do the same for other versions of COMSOL.
Kind Regards,
Arpys
1.- Open Terminal
Kind Regards,
Arpys
26.06.2014, 22:57 MESZ
Thanks for the solution, Arpys.
also worked well with Comsol 4.3b.
[QUOTE]
[/QUOTE]
