Electrostatic field of a conductive cylinder
Hi all,
I'm a newby in COMSOL and I have some experience with magnetostatic calculation.
Now I want to calculate the electrostatic field in a conductive cylinder.
There is some example I can use?
Do you have some advise on the way to model my problem?
Thank you in advance for your help
3 Replies Last Post 11.11.2013, 17:03 MEZ
Posted: 1 decade ago 11.11.2013, 14:05 MEZ
I have simulated a simple capator, basically two rectangular electrodes.
I have used the AC/DC Electrostatics (es) and my simulations seems to be good.
What is not very clear to me is the difference between "Terminal" and "Electric Potential" nodes.
I have performed two studies: one with two Electric Potential nodes where I have specified a certain voltage V0 for each electrode and th other one with two Terminal nodes but I have used the same V0 as before.
There is actually no difference, as I expected, but there should be a difference between the two kind of nodes which I can't get.
Do you have any clue?
I have simulated a simple capator, basically two rectangular electrodes. I have used the AC/DC Electrostatics (es) and my simulations seems to be good. What is not very clear to me is the difference between "Terminal" and "Electric Potential" nodes. I have performed two studies: one with two Electric Potential nodes where I have specified a certain voltage V0 for each electrode and th other one with two Terminal nodes but I have used the same V0 as before. There is actually no difference, as I expected, but there should be a difference between the two kind of nodes which I can't get. Do you have any clue?
Posted: 1 decade ago 11.11.2013, 15:55 MEZ
Francesco,
inside an AC/DC model there is no difference between potential and terminal BC. However, you can connect a circuit node to the terminal and thus include electrical circuitry into the model. That is when you want to use the terminal BC.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Francesco, inside an AC/DC model there is no difference between potential and terminal BC. However, you can connect a circuit node to the terminal and thus include electrical circuitry into the model. That is when you want to use the terminal BC. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 1 decade ago 11.11.2013, 17:03 MEZ
It is clear now, thank you
