Adding a constant, homogeneous magnetic field in the MEF physics model
Posted 08.11.2013, 10:40 GMT-5 Low-Frequency Electromagnetics Version 4.3 0 Replies
I am trying to model the magnetic field produced by a wire with a particular geometry which carries a certain current. I have managed to do this so far by using the Magnetic and Electric Fields interface, where the geometry was imported from a 3D CAD file, and then defined a "Terminal" and a "Ground" connection using the "Magnetic Insulation" options. I then define a large cube with material "Air" to contain the wire structure and evaluate the magnetic field within.
My problem is that I now wish to add to this field produced by the wire a constant, homogeneous magnetic field. I would like to have a field with three components (but not necessarily the same value for each, the same as would be produced by 3 pairs of Helmholtz coils).
I think that I need to set a boundary condition at the faces of my "air cube", but cannot work out exactly how to do it.
If anybody has any suggestions, it would be greatly appreciated!
Hello Fedja Orucevic
