Henrik Sönnerlind
COMSOL Employee
02.12.2013, 14:25 MEZ
I think you refer to the following instruction: "From the Axis to use as symmetry plane normal list, choose 1."
This instruction points out the axis of the selected coordinate system which acts as normal to the symmetry plane. The number of the axis (in the case of the global Cartesian system) is 1-X, 2-Y, 3-Z. So choosing "1" would make YZ be the symmetry plane.
The local edge system for a shell has the axes 1- Tangent to edge, 2 - normal to edge and in the plane of the shell, 3 - normal to shell. The default for a symmetry condition is 2.
There are two reasons why you should not use the symmetry condition as defined by the local edge system (which is convenient):
a) The symmetry plane is not aligned with an axis of the local edge system. This is the upper case in the appended sketch (where YZ is assumed to be a symmetry plane and the shell stretches out in the Z direction.)
b) Due to curvature, there may be a small error in the computed direction. This error will decrease with mesh density, and can often be ignored. This is the lower case in the appended sketch.
Henrik
Henrik
03.12.2013, 07:28 MEZ
Thanks for the reply, but does the N in the sketch represent a normal to symmetry plane?
Since symmetry plane is defined on a boundary, why the symmetry plane is not aligned with an axis of the local edge system? (one of the axis of local edge system is tangent to the edge)
Henrik Sönnerlind
COMSOL Employee
03.12.2013, 08:41 MEZ
N indicates the normal to the shell. The symmetry line is the vertical dashed line. In the case in the lower sketch, the shell normal N is mathematically in the Y direction, but numerically not because of the discretization.
In the sketch, the shell edge in the symmetry plane goes in the Z direction. So the symmetry plane can have any rotation with respect the edge tangent. For most cases, however, the second axis of the edge tangent system coincides with the normal to the symmetry plane (at least mathematically).
Henrik
Henrik
