AC impedance of a dipole
I am at the moment trying to simulate a simple system and I am having a few problems.
I am trying to calculate the self impedance of a dipole located inside a full space of conductivity 0 and permittivity 80.
The dipole is composed of two electrodes represented by two spheres, one is at a potential of 1V and the other is set at the ground. I put the spheres in a rectangle representing the full space.
I would like to plot the self impedance of the dipole as a function of frequency. The self impedance can be expressed as :
Z = (Vt2 - Vt1)/i
Where Vt2 and Vt1 are the potential of the two electrodes and i is the current fed to an electrode. I do a study with in frequency domain : range(1,10,1000).
I then attempt to plot a 1D plot -> Global with frequency in x axis and impedance in y axis.
I do not know what to put in the expression for the Y axis, indeed i would like to plot the formula above but I am unable to find how to express Vt1, Vt2 and i. Is it possible ?
Is there a way to plot directly the self impedance of the dipole with Comsol ?
Thank you very much for your help
Anthony
3 Replies Last Post 04.12.2013, 12:30 MEZ
Posted: 1 decade ago 03.12.2013, 16:26 MEZ
Anthony,
one way to measure the current is to use terminal BC and a circuit physics node that connects to the terminals.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Anthony, one way to measure the current is to use terminal BC and a circuit physics node that connects to the terminals. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 1 decade ago 04.12.2013, 11:05 MEZ
Hello following your advice I made a few changes to the model :
- I put a Terminal at the receiving electrodes (Electric Currents -> Terminal 1 -> I0 = 1A)
- I put an electric potential on the transmitting electrode (Electric Currents -> Electric Potential 1 -> V0 = 1V)
- I put the boundaries of the rectangle at the ground potential as the condition at infinity.
I then complete the study and try to plot the impedance (ec.Z11) as a function of frequency. The plot gives me a constant Impedance not varying depending on frequency (which is unexpected) . I feel I am still doing something wrong.
Hello following your advice I made a few changes to the model : - I put a Terminal at the receiving electrodes (Electric Currents -> Terminal 1 -> I0 = 1A) - I put an electric potential on the transmitting electrode (Electric Currents -> Electric Potential 1 -> V0 = 1V) - I put the boundaries of the rectangle at the ground potential as the condition at infinity. I then complete the study and try to plot the impedance (ec.Z11) as a function of frequency. The plot gives me a constant Impedance not varying depending on frequency (which is unexpected) . I feel I am still doing something wrong.
Posted: 1 decade ago 04.12.2013, 12:30 MEZ
Anthony,
the reference impedance is a predefined value. That's not what you need. Look at some examples using circuit physics. Search on the forum and the knowledge base.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Anthony, the reference impedance is a predefined value. That's not what you need. Look at some examples using circuit physics. Search on the forum and the knowledge base. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
