rigid connector
Dear colleagues,
I need to constrain the center of rotation of a rigid connector with a spring.
Is there the possibility to do that?
It might be easy to do if I could use an existing point as the center of rotation, but I do not know how to do it.
Thanks for any suggestions
Simone
1 Reply Last Post 05.12.2013, 20:56 MEZ
Posted: 1 decade ago 05.12.2013, 20:56 MEZ
Here is a way to do it for a simple linear spring:
1. Figure out the name of the rigid connector degree of freedom you are interested in, e.g solid.rig1.v for a y-displacement in the rigid connector with tag 'rig1'
2. Show Advanced Physics Options
3. Add Solid Mechanics->Global->Weak Contribution
4 Enter the contribution as " -k*solid.rig1.v*test(solid.rig1.v)" where k is the spring constant.
This can fairly easy be extended to a spring which changes direction with deformation etc.
Here is another quicker variant, with a little less generality:
1. Add an Applied force to the rigid connector
2. In the y-component of the force, write "-k*solid.rig1.v"
Henrik
Hi, Here is a way to do it for a simple linear spring: 1. Figure out the name of the rigid connector degree of freedom you are interested in, e.g solid.rig1.v for a y-displacement in the rigid connector with tag 'rig1' 2. Show Advanced Physics Options 3. Add Solid Mechanics->Global->Weak Contribution 4 Enter the contribution as " -k*solid.rig1.v*test(solid.rig1.v)" where k is the spring constant. This can fairly easy be extended to a spring which changes direction with deformation etc. Here is another quicker variant, with a little less generality: 1. Add an Applied force to the rigid connector 2. In the y-component of the force, write "-k*solid.rig1.v" Regards, Henrik
