Linking different variables across assembly boundary
Posted 13.01.2014, 03:23 MEZ Low-Frequency Electromagnetics, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 4.3b 1 Reply
Suppose I have two domains, finalised as Assembly. Variable Ve on the left and Vi on the right. I'd like to set up continuity between those variables. (There is no point in that, I know — just use one variable and Continuity pair — but if I know how to do this, I can solve my more complex problem.)
If I set up an Electric Potential (from the Pairs submenu) under Ve's interface, and set it equal to Vi, there is an error that Vi isn't defined there. This is true, because Vi is only defined at the other domain of the assembly. But the solution to also define it on this part isn't good, because then this additional domain of Vi, where Vi isn't modelling anything and has been defined only to make it available on the left, interacts with the rest of the system (say, if I put a Dirichlet BC of 10 kV on its far side, all the voltages go up throughout the model).
What I need, somehow, is to be able to define Vi on the right domain, and also just on a boundary of the left domain, for the purposes of making it available there. Is this possible?
-- Evgeni.org
-- Evgeni.org
1 Reply Last Post 13.01.2014, 04:08 MEZ
