Heat transfer physics for both fluids and solids with time dependent solver
I am stuck with my model that I try to couple three physics. I include electric current, creeping flow, and heat transfer in solids. Heat generates due to Joule heating inside of the fluid (defined as a heat source), and dissipates through the solid wall. Therefore, under the heat transfer in solids, I defined both solid and fluid domains since the heat transfer occurs through both liquid and solid.
The problem I am facing now is that the model does not solve with time dependent solver, while stationary solver gives me a reasonable resultant temperature.
I will greatly appreciate if someone can help me. Attached is my model.
Thank you very much for your help,
1 Reply Last Post 28.02.2014, 00:30 MEZ
Posted: 1 decade ago 28.02.2014, 00:30 MEZ
Sorry, I forgot to attach my model. Here is my model.
