Size Limitation of the probe table?
It seems there is a size limitation of the probe table to 9999 time steps/data lines.
The contents is treated like FIFO, i.e. the time steps computed first are replaced by later time steps.
Is that a fixed limit or something that can be adjusted?
2 Replies Last Post 11.03.2014, 10:32 MEZ
Magnus Ringh COMSOL Employee
Posted: 1 decade ago 11.03.2014, 10:20 MEZ
The size of the buffer is 10,000 rows by default. You find that setting in the Probe Table node's settings window, under Storage. If you choose to store the table in a file instead of in the model, no size limitation applies.
Magnus RIngh, COMSOL
Hi, The size of the buffer is 10,000 rows by default. You find that setting in the Probe Table node's settings window, under Storage. If you choose to store the table in a file instead of in the model, no size limitation applies. Best regards, Magnus RIngh, COMSOL
Posted: 1 decade ago 11.03.2014, 10:32 MEZ
Thank You!
Thank You!
