failed to find a solution when coupling heat transfer with fluids dynamic!!
Posted 24.03.2014, 13:01 GMT-4 Fluid & Heat, Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD), Mesh, Studies & Solvers Version 4.1 0 Replies
I'm trying to model a transformer using multiphysic (thermal, fluid dynamic) modeling on Comsol.
when using only the thermal modeling, (only using heat transfer physics)
the program is running.but when adding the Fluid to couple the two phenomenon (using non isothermal flow) i got a divergence error
Failed to find a solution.
Returned solution has not converged.
Any ideas? Attached you will find my model. Thanks.
Hello Me Cse
