Comsol axisymmetric problem
I want to model an 2D axisymmetric solenoid in a magnetostatic conditions, but when I want to put the boundary settings I can not see it, it doesn't appear at the physics.
Ema
1 Reply Last Post 31.03.2010, 15:24 GMT-4
Posted: 1 decade ago 31.03.2010, 15:24 GMT-4
I'm not sure I catch fully your problem, but if it is that you want to define some physics on an interiour boundary, that normally are greyed out as the default conditions are "continuity", you must turn them "ON" by selecting the check box just below the boundary item list, next to the "not active here"
Hope this helps
Hi I'm not sure I catch fully your problem, but if it is that you want to define some physics on an interiour boundary, that normally are greyed out as the default conditions are "continuity", you must turn them "ON" by selecting the check box just below the boundary item list, next to the "not active here" Hope this helps Good luck Ivar
