calculate transmittance using ray tracing
Owe to some optical element are far greater than the wavelength,so I try to use geometrical optics to simulate the light propagate in optical element. But how to calculate the transmittance in it. A simplest problem iswhen a ray passes from air to water, how to calculate the energy of the reflected and refracted light with ray tracing method.
Thanks!
4 Replies Last Post 13.11.2014, 22:59 MEZ
Posted: 1 decade ago 29.03.2014, 17:24 MEZ
Which module are you using? Does the equations solved there really contain more information than traced ray?
Pu, ZHANG
DTU Fotonik
Which module are you using? Does the equations solved there really contain more information than traced ray? -- Pu, ZHANG DTU Fotonik
Posted: 1 decade ago 31.03.2014, 03:43 MESZ
Thanks for your reply. I used geometrical optics to solve it. But I can noly obtain the track of the ray. I wish to calculate the transmittance of every refracted and reflected ray.
Posted: 1 decade ago 31.03.2014, 07:40 MESZ
I never used geometrical optics module, but I doubt it holds more information than ray trace.
Pu, ZHANG
DTU Fotonik
I never used geometrical optics module, but I doubt it holds more information than ray trace. -- Pu, ZHANG DTU Fotonik
Daniel Smith COMSOL Employee
Posted: 1 decade ago 13.11.2014, 22:59 MEZ
This is now possible using the new Ray Optics Module which was released with V5.0:
www.comsol.com/ray-optics-module
Some example models can be found here:
www.comsol.com/models/ray-optics-module
Dan
This is now possible using the new Ray Optics Module which was released with V5.0: http://www.comsol.com/ray-optics-module Some example models can be found here: http://www.comsol.com/models/ray-optics-module Dan
