Draw à 3D triangle
Hello, I try to draw a 3D structure representing an isosceles triangle with a regular height. I used the polygon drawing, but fails to define the pattern as a solid.
Thank you in advance,
Josephine
3 Replies Last Post 03.04.2014, 14:16 MESZ
Posted: 1 decade ago 02.04.2014, 19:34 MESZ
Do you mean a triangular prism?
Posted: 1 decade ago 03.04.2014, 12:58 MESZ
yes
yes
Posted: 1 decade ago 03.04.2014, 14:16 MESZ
To create a triangular prism, you can draw a triangle in a workplane and extrude it.
These geometry operations are documented in Chapter 6 of the Reference Manual, version 4.4.
To create a triangular prism, you can draw a triangle in a workplane and extrude it. These geometry operations are documented in Chapter 6 of the Reference Manual, version 4.4. Best, Jeff
